85 22r propane prob
rockcraw
Active Member
:dunno: I have a yota crawler 22r running on propane I can start it and it will idle but as soon as you touch pedal it cuts out and dies, I dont know what it could be I've tried switching tanks, I am guessing it could be propane setup but I could be wrong. I just need someone to point me in the right direction on what this could be. Any input would be greatly appreciated thanks.
we had the same problem and changed the hot wire location and it worked. we have the truck tore down right now so i cant tell you for sure were to hook it up, but i think we hooked it up under the dash in the fuse block.
Thanks man, who ever wired mine they wired it in to headlight harness. I will move it to a different 12 volt source like fuse panel and give you feed back. Thanks again.
we have a got propane kit on ours and the white wire to the left on the fender well is what we had to relocate to a hot wire that was hot all the time.
I ran wire directly to fuse box like was recommended still same thing. At first when I started it up today it sounded or was running real sluggish, I let it keep running after a minute or so it smoothed out but couldnt get it to idle up when I pushed the pedal. I started messing around with the adjustments on the carb the biggest brass bolt thats threaded and it tappers off getting smooth all the way to the tip which should let more fuel or pane into the carb which should idle it up I took it out and the truck does nothing but idle but you can screw it in and it eventually idles it down shutting it off. ANY MORE SUGGESTIONS FROM ANYBODY PLEASE!!!!!!!!!!
a guy I ride with said his would idle and not rev up so he put a bigger breather on it and runs fine now. I dont no much about it but just thought id mention it
thanks I'm wondering if something could be stopped up in the mixer or the lines itself.
EVERY PROPANE SETUP I HAVE HAD THAT GAVE A PROBLEM I ENDED UP WASTING MONEY TRYIN TO FIX IT WITH REBUILD KITS I WOULD SAVE TIME ND MONEY AND JUST GET NEW STUFF
I agree, I've got some stuff on the way decided to go with an Impco 125 mixer. Thanks for all suggestions.
