Ok, so i finally looked at it after work today in the parking lot. It blows ice cold air all the time. :rb: The blend doors seem to be working. :cheer: They are moving underneath the dash. it goes from defrost, to floor, to vents no problem. The fan blows faster out the vents when you put it to cold instead of hot.
The AC compressor is always cycling. Even with it on defrost and all the way to hot, it just keeps cycling under the hood.
Now for the strange part, and this is all while running. It runs at a steady 210 indicated. The top radiator hose gets super hot as it should, but neither heater core hose heats up. The top just barely, the lower ice cold. The top one has a little pressure release/fill valve inline. I opened it, pretty much nothing. I pulled the top hose off at the thermostat, nothing but fluid coming from the radiator, down the radiator hose, and out the heater core nipple of the thermostat housing.
I pulled the lower heater core hose near the front of the engine, again nothing. I waited a little and fluid started coming out of the hard line I pulled the hose off of.
I put it all back together, drove it around, no change on the temp gauge. Came back, opened the pressure/fill valve, nothing. Opened the radiator cap, pressure as it should:redneck:. I could not see any kind of flow from the upper hose into the radiator though. Seems the thermostat is completely stuck closed, or the water pump isn't working. But on the other hand, it isn't overheating or erratic temp at all. I'm gonna tear into it in my garage Friday. Wish me luck:haha:
