A quick Ranger question:
The 2.0 however... is ball less and was carb'd to the end in '88. Avoid those.
Are you wanting a 2wd? 4x4? Avoid the 85 and later auto too.. the A4LD brings teh suck.
A 2.9 is a good motor and I get about 17-20 mpg if you can't aford a 4.0
x2 Just make sure you get a later one with the good heads, the early ones were prone to cracking, the easy way to tell is the later (better) ones had the lip on the valvecover turned up, the older ones were turned down.
