I did one on my truck (should showed you while you were up here...
I had a fitting attached to the outlet side of the AC pump hoses to attach my air fittings, i had it done at the local parts store. Make sure to put a pressure on/off switch in the mix and a pressure relief valve, the bastard will blow your hood off if you do it wrong and it continues to pump! :redneck: Mine is not one of the big bulky york ones, i think the yorks are more durable in the long run, but mine has seen it's fair share of use and abuse (after most runs, it would fill up all my tires and and two other trucks tires one after the other...) I need to put a filter on the inlet side but it seems to not care too much.
The theory will be pretty much the same no matter what, pump-lines-tank-gauges-regulator-switches-etc. but the sizes and way things attach might be different.
