why not 2 stroke? what cylinder pressures are we seeing with combustion? maybe they are and they didnt' show it. seems like you could shove 200psi in (and have that sitting on top of the intake vavle) and then exhaust it on the upstroke, repeat. also, I wonder if they scavenge any of the exhaust. neat as ****.
where do you get your heat in teh winter? why not have a compressor that only engages the clutch when you let off the gas or depress the brake pedal, as in when you are coasting or decelling, like an engine brake. not only does it slow the car, it compresses are. since you cna't make energy, you can run it while you are under power, but if there was a clutch on teh compressor that only jumped in while coasting, you could scavenge you energy you are giving away to the brake pads.
