Air shock charge kit
socsmm6
Any suggestions on a source to charge air shocks other than the 400.00 kits like poly performance?
Hose, regulator and zero loss chuck off eBay (chuck from Kartek if needed) and a bottle from local welding shop.
Half of that or less
Does anyone have an exact place or part number/brand for the regulator used? I think it requires higher psi than the one I have...
Found a 400 psi regulator on eBay for 60 bucks. Course I would not know a good one from a bad one
I got mine from air gas for $72
When I built my kit I put quick connects on everything and made hydrologic lines so it would take the pressure.
I prefer using a regular air chuck compared to a no loss.
The no loss chuck won't work on my old fox shocks anyway. The shrader valve is too deep and the pin won't hit
How did you check pressure. I couldnt find a high enough tire gauge, so I bought the no loss gauge but have had issue fitting it on some coilovers.
With the outlet gauge on the regulator.
I hold the chuck on the shock, the gauge reads what is in the shock
, then I turn the bottle on and raise the pressure on the raise the pressure on the regulator to whatever I want, then put the air in the shock.
Lower truck, check ride height, repeat steps and gradually raise pressure till I get it at the height I want.
I used our nitro tank at work we use for filling tires.
Held the chuck on by hand, turned the knob until I had desired pressure. Usually lost about 8psi when released so I'd add 8psi when setting pressure
This is what I got its 100.00
I started to call craig but as muck as I change things around I would be better off getting a kit my self. I picked up a few items off ebay today. no loss air chuck with a gauge and a regulator with a high pressure air hose. gotta pick up a bottle of nitrogen next week.
Thanks for all the suggestions
