Am I ready
kid rok
To do list:
Weld on limiting chain on rear
Weld on connection point for rear winch
Fix leaking rear axle seal
Fix weird noise in trans
Install front drive shaft
install front dif cover and add fluid
Change engine oil due to crank ripping off my inside baffle of oil pan.
Install cutting break.
Rebuild passenger king pin
Rebuild passenger shock
Repair hole in roll cage
Fix cb and radio
As booty fab as my rig is ya"ll will be lucky to go up half the stuff I do. :flipgotcha: Oh ya air bumps are done.
6uldv8 said:
Sounds like a "Blacksheep to do" list but needs about 9 more paragraphs of explanation to compete with Kelly's skills! ;D
For a guy that doesnt like to type... he sure likes to type. :flipoff1:
Had to post up. You guys have an awsome forum, and it seems that everyone is full throttle. I like it , I like it alot.
Thanks man, we look forward to wheeling with you !!
kid rok said:
To do list:
overrated
if it leaks, you always have fresh oil in it when you top back off
it will present itself soon enough, just wheel it
you probably need all those
Fix cb and radio
meh
:flipoff1:
