anyone else running a stak 3spd?
Stak keeps popping into neutral on steep climbs/obstacles. Could have killed me this weekend. Stak says I need to increase the preload. Did you need to do that with Joe's?
Rear output side of the case is leaking. The leak is very slow (table spoon a day or so) but it's hard to tell exactly where it's coming from.
Shifters are loosening up but are still really really tight.
thoughts?
thoughts?
I didn't have to do anything to joes except weld the tube that the shifters sit on to the adjuable shifter plate---otherwise just bolt it up...
You should be having ZERO problems with that case---you should have to do NOTHING to that case....
