ARB relay leak
whiterice
Lynnwood
Last few times out my ARB compressor has been turning on more and more frequently. Last time out it would fire off within a few minutes. So today I went to find my air leak. At the top of one of the ARB relays air is passing out of the center of the open threaded hole even when nothing is active. If you know the relays, there is a open threaded hole in the base switch that the electrical relay is slipped over and threaded on with the little thumb screw nut. So my question is can that switch be repaired or is it just an R&R deal.
I had a problem with one of mine once. Seemed like something was sticking or valve not doing its thing. I took it out shook it poked at it and put it back in and it worked. Maybe a little drop of air tool oil in it or blow it out or something
