ARB Soloniod Vent
crash2
-Oh no I picked a side-
12
Da gold bar
Anybody know where to get inserts for an ARB solonoid for the vent so you can plug a vacuum hose to(reroute where the air goes)?
no no--- Ok on the soloniod--where the pressure vents when you turn the soloniod off--that hole is threaded for a hollow threaded insert so you can put a vacuum hose on it--to direct where the air goes to....
Trying to re-route that puff of air so that it blows up your pant leg every time you turn the locker off? :D
Are you just bored? Or are you trying to prevent contamination? It seems like it should be pretty maintenance-free the way it is. If you get something in the port, the air blows it out next time you de-pressurize, right?
That said, can you find an NPT tap that's close and put in a little pipe nipple (I have no idea how big this port actually is)?
if I remember correctly those are metric threads...
all the tubing is metric..
at least that is what I found when I was looking for parts for mine.
I ended up ordering stuff online when I did a google search for the metric tubing and fittings...
but I could be mistaken.. those aussies do some different things down there.. LOL
