Are your lug nuts tight?
boxboy
can I be your friend...
Monroe
How often do you check your lug nuts on your wheeling rig? How about your trailer have you ever checked the lug nuts on your trailer?
After you have removed a tire to repair your rig do you check your lug nuts out on the trail the first stop you make?
Never check the ones on the Jeep, it has 8 but in theory only needs 3 :redneck:
...the trailer I check once in awhile before a long trip.
The real question Scott............
How often do you check link bolts??? LOL
I check them right after they brake and fall off :booo: Ok ok the Tj is up on jack stands and after I finish some stuff on mine tonight the TJ is coming apart maybe I will start a TJ rebuild thread :redneck:
that was a fun fix in the snow, when its getting dark, on BYS :haha: Not to mention a broken coilover shaft
Oh there was another "issue" this last weekend with someones TJ I was test driving before I started the rebuild
I seem to have bad luck with links :booo:
i grease my wheel bearings and check nuts on trailer before i take it out. If you have wheel spacers...check every other trip ive had mine fall off about 5 times. lugs....not so often.
