atlas support??
skipnrocks
2
Billings Montana
I am supporting the back of my atlas and built a xmember that runs the length of the bottom and has 5 of the bolts that hold the bottom pan in place so it is being supported the entire length. Is there an issue with this since those bolts arnt long or real big? The whole drive train is solid mounted. My thought is it is mainly meant to keep it from bouncing downwards but I thought my logic might not be sound.
please advise.
The EOR one is simple and im sure it works well. However you have to remove the yoke to install it. With the limited amount of room I have in the single Seater the TMR one is 2 pieces and bolts and the tail shaft with 2 bolts. Therefore I can remove the 2 bolts and drop the case out the bottom if I ever need to. Worked out really well for my application. Now its finally time to ride again
We went with the EOR unit, but i'm using bushings so i mounted the trans and transfer case on the same crossmember so if the trans moves so will the transfer case, i called to see if i need a brace they told me not to use one, but screw that, hanges out there too far...L
Re: Re: Re: atlas support??
zayne2427 said:
here is how my buddy Mo did it on mine with a TMR customs atlas support ring.
This one just wanted to be placed there...fit perfectly.
On the buggy I was building, the main support was mounted foot up due to packaging.
