TigTorch
So I got real lucky on this one. Found this while inspecting the under side of my heep. On closer look I found the clip for the opposite side of the cross completely gone. What
Thanks for the info guys! I had no idea the caps would rotate in the yokes. Makes perfect sense now how the clips were coming off.
So I took a paint pen and marked across the caps before going out. This is what I found after a day at Reiter. Sure as ****, the caps are rotating. Moved 1/8 to 1/4 turn.
So does this mean the yokes are already stretched and I need Superior or Alloy aftermarket axles or can I reliably save these by grinding for full clips ?? Once the caps start rotating can the axles be saved??
I fully weld my caps in.
PITA to get apart, but I haven't had any problems so far.
