Bad steering Feed back
crawler1
1
Southern Ill
I have been messing with this for a while and cant figure it out . It is happening on both of my rides I get really bad feed back out of my hydro system like when you are trail riding and hit a little rut in the path it will jerk the wheel out of your hands , and the same thing happens when you are climbing an obstecial in the trail for instance ( when i was at Gray rock last time coming up buzzards roost ) my right front tire kept biting the wall on the passengers side , and taking the wheel out of my hands and trying to climb the wall . Both systems are from PSC . both are running huge coolers and TC pumps . The one has a 2 x 8 cylinder and the other system has a 2 x 10 cylinder .. Also when i Jump either one it will gerk the wheel back and forth out of your hands . Any help would be Great .
My .02 cents. Lets break it down. what pump, what valve. the lines you have are they the right size and do they have the right fitting? Ex.You could have a -6 hose with a -6 fitting but the inlet is smaller on the fitting restricting your fluid.
Also is the whole steering set up PSC? if it is call them and they should be able to solve the problem. If your mixing parts, that could be your problem.
Conclusion > I think you have a bad valve. or steering cylinder.
Or it could be that your using PSC, Not howe :flipoff1:
Yea its a full PSC set up both are .. Im thinking about getting a new pump that Mr Cole told me to get and run . He runs it on all his rides and the ones he builds .
