Bell won't fit into the inner c or through the hole in the knuckle?smurfy90 said:I has a mini spool up front. The bell will not fit into the knuckle. On there youtube video it makes it look easy because the chunk side of the shaft is not inside the splines so they can move it enough to slide it together. No ADAM not a dumbass!
Cant with a d44. Balljoints will not go back together.BUG-E J said:I pull my knuckles off to do mine.
Watch the video I linked and then go back and look at top pic.al1tonyota said:Bell won't fit into the inner c or through the hole in the knuckle?
. Or pay some neighbor to do it?BUG-E J said:.
Ha took his ass 2 days.SHELBS44 said:. Or pay some neighbor to do it?
In your top picture it appears your knuckle is still on the axle assembly?smurfy90 said:Watch the video I linked and then go back and look at top pic.
Keep in mind that is a 3/4 ton knuckle in the video. And the inner shaft is able to move around to where these cant because its inside of the splinesal1tonyota said:http://www.rcvperformance.com/videos.aspx
Even in the video it looks like a pita to get together but obviously works! Guess some folks just don't got it!
We removed the knuckles also. The bell is in the way of the ball joints going back in. The problem is resolved. There going back to rcval1tonyota said:In your top picture it appears your knuckle is still on the axle assembly?
good job!smurfy90 said:We removed the knuckles also. The bell is in the way of the ball joints going back in. The problem is resolved. There going back to rcv
What year model? Did you order the right ones seems there are two sets?smurfy90 said:Also the wagoneer Knuckle is smaller than any other d44
Batmobile Will said:I've not had any problem with RCV they have warranty Anything that I have broke and doing study's now trying to find out why I'm keep braking them top customer Service and I've never heard of a off road shop that could not Clarence a toy axle to put in a RCV
