Bleeding Brake Problems
xjoffroad
Everett
Started to bleed my brakes yesterday and found out that I needed to replace my master cylinder because it was leaking. I bench bleed the master cylinder before I bolted it back on like the instructions say. Tried to bleed my brakes today and I bleed all 4 corners about 3 dozen times. Pressure builds up and there is no air coming out of the bleeder valves. Once I turn the XJ on the brakes go done to the floor. Its not leaking brake fluid anywhere I can see. What is wrong?? Im getting pissed! :mad: :mad:
What year? ABS or not? Does it have 2 lines going to the back? Can you get a pic of the combo valve? (mine had an extra line I had to open to let the air out)
Start by narrowing it to a corner, or an end. Pinch off soft likes until you get a good firm, extra firm actual, pedal.
It could be your rears are way out of adjustment.
it a 89. no abs. 1 line goin to the back. i dont have an extra line
i have bleed the rears, not kiding, probably 13 times. :mad:
This has been a frequent topic on the Naxja boards, and I have never seen a solution posted. You are screwed.
Seriously though, have you tried starting and pumping the pedal several times? I know on the early XJ's the brake booster sucks. It failed on my 88 and had to be replaced. Check your vacuum line to it.
