R
Ricky@BlueTorchFab
Guest
Tired of non-rebuildable unit-bearings failing due to poor design/pre-mature wear? Here at BTF we believe we have come up with a solution. We have developed a spindle and hub set-up that will be a direct bolt-on replacement for a Ford unit-bearing(as well as SpiderTrax). There is no need to change your brake set-up, as the wheel mount surface is in the same location. The only thing you need to change is your stub shaft if currently running a unit-bearing axle.
The two main advantages of a unit-bearing are ease of removal, and length of the hub protruding through the wheel. Our Unit-Bearing Eliminator is removable in the same fashion as a unit bearing (as a complete assembly by removing the 4 fasteners from the knuckle) or can be serviced on the vehicle like a traditional spindle and hub. Our kit uses Dana 60 spindle bearings and seals. Our hub is 2" longer than a Ford unit bearing, and can accomodate a locking-hub or a drive-flange.
The spindle is machined from 4140 quenched and tempered; the hub is machined out of 7075 billet aluminum.
If you have any questions feel free to ask. Any input would be appreciated.
Complete 8-lug Kit (Kit does not include knuckle/axle)
Exploded View of 8-lug Kit (Kit does not include knuckle/axle)
Side View of Hub and Spindle
Spindle
8x6.5 and 8x170 Lug Patterns
6x5.5 Lug Pattern
Complete 6-lug assembly
We also have rear spindles for 3" .250 wall and 3.5" .250 wall axle tubes with 3" of engagement inside the tube.
Spindle
6x5.5 Lug Pattern
