bobbing a bed
when you guys bobbed your bed what welder did you use?
im goint to start to weld mine up tomorrow and didnt know which one to use
and did you weld both in and out?
Turn down your amps and wirespeed, MIG
Fluxcore or use some gas one with argon/co2 mix
Spot weld all over the damn place, you dont want the sheet metal to warp...
well i did it with the .30 gasless wirefeed basicall a bunch of 1 inch welds took me a long time cuz i didnt want to warp it but the truck wasnt that straight to start with
i took 10 inches out tho
I used a cheap little gasless wirefeed, worked great.
I took 16" out of mine and used a piece of the cut-off to patch a dent.
And your question about welding the inside of the bed. What I did weld a 1" piece every six inches or so. And then used seam sealer for the rest of it. It's way too much welding to try and weld all of it.
