wizzo
my current setup on chevy dana 60 and 14 bolt:
front: chevy 1 ton front calipers, pads?, braided line, wilwood 7:1 pedal and 1" MC, residual valve right off MC
rear: chevy 3/4 ton calipers, wagner gold? pads, braided line, wilwood 7:1 pedal and 7/8" MC, residual vavle right off MC
the front and rear axles are two seperate systems. the front definately won't lock up at all on or off road and the rear will off road but feels mediocre at best. in high range it will hold on flat ground but in low range it's not gonna happen. the pedal feel is ok, it's not too stiff and the travel feels right but something about the system is off.
basically, i'd like to know what is working for you? if you're running a similar setup that works well what is different about yours? i've thought about trying some different pads (black hawk, ebc, etc) but hate to spend the money if it's not gonna do the trick ultamately.
i've found a setup for the front that is proven and i'd like to go to eventually but it is $$$$$ with a custom hat/adapter, ww rotor, ww 4 or 6 piston calipers and ww pads.
let me know if you have any suggestions to help my ****ty brakes.
