Brake tech
skipnrocks
2
Billings Montana
I drove the buggy for the first time today. The brakes were soft and I couldn't figure why? When I drove i
It the rear tires would just spin. So I figured there must be an air bubble so I tried to bleed and not a single bit of air. Flow seems consistent with what's coming out of the front brakes when bleeding them? Ideas?
Ford Mustang hydroboost.
Stupid question I know, are the bleeders oriented correctly? Maybe need a proportioning valve. I had to switch ports F to R on my master when I got my buggy and that helps. What calipers are you using, may require more fluid volume, (bigger master cylinder bore).
I have mine switched front to rear already. Fronts brake awesome. Tears are 1/2 ton calipers I think. It's the kit blacksheep sells. Bleeders are up at highest point. Is that correct?
Yes, bleeders facing "up"
Could be air trapped somewhere we had one setup like this we had to bleed half a dozen times and finally got good brakes to the rear. Wish I was closed I'd give you a hand with it.
Thanks that would have been great. After re bleeding them I read article that said it often is from poor bench bleed. So I cracked open at the mc and re bled at the master and got a nice bubble out. I hope that's the end of that. It was interesting being in two low with only front brakes for the first drive. Lol.
