Broken toyota drive shaft
Chuck19
Manchester tn
I broke the CV joint on my taco yesterday and I'm wondering if anyone make a stronger CV joint or shaft to replace the toyota stuff?
I'm thinking of doing away with the CV joint all together sence it's a dedicated trail rig any thoughts on that?
Any chance the CV bottomed out causing it to break? The IFS CVs do not have very much travel. I would check with the suspension at full droop and see if the CV is binding.
If you just want to replace it anyways, a standard u-joint will be stronger than a CV. thumb.gif
When i first got my junk together, I used a stock front toyota shaft in my rear, first 15 minutes of the day, the cv broke, replaced it, broke again! had that crap cut off, went with a single joint, no more problems!
No this is on the rear and I was the reason it broke lol
It was in the truck when I bought it so I'm not sure if its part of the original truck or not I just want stronger !
Re: Re: Broken toyota drive shaft
What part broke?
Only thing stronger will be a 1350 cv or one of the larger high dollar aftermarket options
the later model CVs come on the rear factory (Tacoma/3rd gen and later 4Runner) actually have as much or MORE angle than the old straight axle CVs.
96+ Toyotas do not have CVs on the front driveshaft
I used 4th gen 4runner rear driveshafts to build the shafts on the Gremlin.
I checked all the CVs that I had when I was building them, and an 85 model CV was capable of ~32 degrees, IFS front CV ~22 degress, and the 4th gen Runner & Tacoma rear cv would do ~35 degrees.
I don't think it was the angle that got it it was the double low and 4th gear 39 in stickies lol the angle is not to bad on the back shaft when it's setting level.
I'd weld another one on and keep going
and build a spare rear shaft.
complete rear driveshafts are only like $12 at the pull a part
Chuck19 said:
Ok thanks I just didn't know if there was a stronger version I could use I think I will do away with the CV joint anyway.
I'm pretty sure I have some Toyota CVs that don't have that big hole in the middle of the H cage.
That looks like where your broke through at.
This ^^
