blacksheep10
XBJRA champ/ 555 and team Nasty codriver
okay, wish I had pics of what I am going through here, heath has my camera, but here is the gist of it. a 231 doubler is a great idea for the money. it goes with a circle 6 case. problem is I need chevy side. now, doing measurements on my ford case I came up with not enough spline engagement anyway, so I had to ditch the clocking plate to do ford side. worse than that, my chebby case is figure 8. I had to ditch the whole rear plate that caps off the 231 and make a thinner one out of steel. then I took a figure 8 plate I had to make a doubler out of (203 doubler) and am welding it to the steel 231 plate I made and drilled. alignment adn clocking are a fun issue. I don't think I have any fawking floorboard left at this point. now I have these 2 steel plates that look like swiss cheese welded together and have to cap off the front of the 205 shift rail hole because it hits the 231. I have welded a little piece of steel to the 231 plate to cap off the hole and am going to silicone it shut. after that I have sharpened the end of a shift rail to 2 points like and end mill and am running it through the shift rail path to mark the back of the output housing for the spot to drill the hole and put the seal. I am going ghetto and jb welding the seal that I take out of the front to the output housing and siliconing the **** out of it. then I am going to join 2 shift rails together to get enough length out the back of the case. I will then cut the original rail off at the front to make sure it will travel forward into high without hitting the block off plate and cut teh rear of the extended part off to the desired length. in all reality it isn't too bad, just a lot of test fitting, thinking and drilling. I actually think it is fun, I like doing this kind of ****, but it is time consuming as hell and that is what eats me up. I want to be working on other ****
