H
Hotrod
Guest
**** NOTE TIME EDIT ****
I previously stated there would be no comp. Tony called me just now and revised the statement saying there WILL be a Cable Hill Comp. on Saturday Sept. 11 only. This will be a precurser to what will come in November. These are the rules for this comp.
Drivers meeting and payup at 4:00 pm, Now 3:30PM
10 driver minimum
2 hours of comp only
$25 per run, run as many times as the 2 hrs allows in order behind drivers who haven't went
5 min. maximum for each competitor
75% payout
Draw for possisions
Line up at bottom and go to the top
Air horn and hand timer with a non biased person will be controlling timer
Comp. starts at 5:00pm sharp Now 4:00PM
You must make the drivers meeting to enter
You may run the hill as much as you want untill 4:00pm Now 3:00PM
Hill will be DRY unless weather changes that
You must have all the appropriate safety equipment required for the park
Tony also mentioned he will be fixing the bottom for a smoother take off!! This should be good!
Please pass the word and add this to any other forum( Tony's request)
10 driver minimum
75% payout
Draw for possisions
