car trailers with winches?
Here's mine:
Mine's bolted to the front of the deck. Easy enough.
Someday I might make some sort of flush mounted receiver assembly, or a hidden winch under the decking. I like the deck to be completely flat sometimes. If it was a car only trailer, just bolt it on top.
If you make a cover or mount it in a tool box or something it will last longer.
________
Lesbian Humping
I just drilled a couple of holes and mounted it to the deck. A couple of welded bolts and it won't disappear. The trailer is 20' long so the room it uses isn't a problem.
do you use the upside down plastic tub as a cover?
