So I had an old fire stick that was beaten all to hell so I replaced it with a fancy new 102" stainless whip, I put the radio on the swr meter and it jumps to over 3. I than had a look at the coax figuring that was the problem and found the sheild wire was rubbed through in a spot so I replaced it with some new high dollar coax at 18'. I put the swr meter on and I still am getting over 3. The antenna is mounted on the bed rail right behind the cab, that wouldnt make that much SWR would it? Im gonna try disonecting my woofer amp and see if that help but I def need some help if you have some suggestions.
Oh, I tried using my buddys radio and got the same results so its not the radio.
HELP!!
HELP!!
