Chevy 3/4 Brakes
BamaTJ
Hardline Crawler
Gardendale, AL
P do you remember what size the banjo bolts on Chevy 3/4 calipers is? Trying to get some proper brake lines that are long enough for my front droop and need to know what size the banjo bolt is. I believe it is 7/16" but want to make sure I am right.
Man I dont know of the top of my melon... Ive always just got them out of the HELP! section at the parts store.
You gonna do some braided bling bling ? Im tryin to decide how and what Im gonna plumb the buggy with. Let me know how much you spend and what you spend it on. :popcorn:
I thought my brake lines were stock TJ but I forgot I drilled the banjo bolts out for the chevy 3/4 calipers. I went to gdale performance and got some banjo adapters, braided lines and fittings to adapt the line to 3/16" hardline at the frame. $60 for the front axle, hard line to the MC would add only a small amount.
depends on year and other ****. I have several sets of calipers around here and there are about 3 different sizes of fuggin bolts/threads. you need to pull one to be sure. I swapped calipers/hoses again on my caddi truck saturday and had to drill a chebby line that was bolted on a seized up caliper to get it on another twin caliper...twin except for the bolt size.
i know it's late, but i just saw this thread....
the abnjo bolts i have are 7/16-20.....if that helps any.....
Now you tell me after I got to Homie Zone and have them pull a caliper to check! :flipoff1:
better late than never, right...its the thought that counts...and besides...you prolly remembered something else you needed while at Vato Zone .....
