Juan_Hong_Loe
That's dumb
I am having an issue with mounting my coilover on top of the steering arm. When it is at full stuff or at ride height there are no problems. It's when the coilover is extender all the way out is where I'm having my issue. So here is my question, should i mount the coilover like in the pic below? I have Swayaways on it and their misalignment spacer reduces the heim from a 5/8" dia to a 1/2" dia bolt. If I run the misalignment spacer provided it binds no matter what. I have mocked up some temporary brackets on the other steering arm (too ugly to show) and I got almost all the binding out, also taking the provided misc spacer out and running a 5/8" bolt with temporary spacers. My problem with mounting them close enough together so it just has barely enough room to clear and not bind puts the brackets about in the middle of the king pin bolts. Whatcha got for me Hardline? Do you think there will be too much shear force on the 5/8" bolt with the brackets mounted that far apart?
Knuckle pointed straight no problems.
Not so much a problem with it turned this way.
Lots of binding turned this way.
And edited pic to show easiest way to cure problem(no I'm not an artist)
Daniel
Daniel
