drich394
www.davesoffroadsupply.com
Ok, I'm a bit of a dumbass when it comes to coilovers, I have one that has just had new seals put in for a massive oil leak, now a new one, not oil thought, nitrogen....I fill to 300psi and I can hear a small leak, put some soapy water on and found it at the bottom of the valve assembly, tightened to inner valve, and replaced it , then I finally removed the valve assembly and put some teflion tape on, reincerted and still leaks, now question is should there be an O ring on the back side of the valve assembly??, cause there is not one..... Sorry for being a moron..
FROM THE EMPTY BOTTLE!
