MattB
every tool box needs raisin wipes!
This is the first set of coilovers I've run and I'm trying to calculate spring rates with sway-a-way's online calculator and I don't know if I'm punching the numbers in the wrong spot or what but the rate's seem bad low to me. I was wondering if anyone could help.
total buggy weight: 4260
front left corner
total corner weight: 1160
unsprung weight: 740
sprung weight: 420
droop: 55%
distance to pivot point from shock the same as distance from centerline of wheel: 48in
angle: 24 degrees
it comes out main spring rate: 135 tender spring rate: 90
sounds way to low to me, am i punching the wrong numbers in or what?
front left corner
sprung weight: 420
droop: 55%
angle: 24 degrees
