skipnrocks
What do you use on your buggy is to turn the electric fans on and off? Do you just use the switch when they're always on? Or do use a controller?
patooyee said:What engine? My ECM controls mine just like it did stock.
RustyC said:Relay from ignition switch. Switch on = fans on.
skipnrocks said:It's on an lq4.
patooyee said:Your ECM has the ability to control 2 fans independently in stock form using only the factory coolant temp sensor. It doesn't get simpler than that.
