Cross Over steerng
charliesnyder
Spanaway
is it necessary to buy a full cross over kit or can it be built?
I dont have the money to drop on a full kit but i have most other parts to do a lift..
any ideas
________
Suzuki TS125 DUSTER
my steering is home made crossover,it can be done ive actualy got two set ups. the thing is they are junk these set ups are made good, but something always fails the links have bent into many shapes the stock tie rod ends break off. this set up has left me sitting in the trail pissed :mad: off more then once.. i havent gone wheelin since september because i am not going out with a half ass set up. im waiting to buy the high steer kit. just my opinion it sucks dont make your own buy the kit i have to and miss wheelin :booo:
Yea i would wait and save up and buy the full kit, if you make it yourself, like crapyota said, it will fail a lot more aften than not its just not worth the time and hassle of making your own
Sounds to me like you guys are possibly using the wrong materials... Bending the links? Obviously youre not doing something right, either tube size or geometry. Or, if you are using the same tube size as what comes in the kit, what makes you think buying the kit would be any better? Also, breaking the stock TREs off? Crossover kits use FJ80 TREs, not stock truck ones. You're using the wrong parts. Just my two cents.
Kits can be built. Just get some arms for a couple hundred, and build off from there with the TREs and tube. The kits usually have a 1.250 OD 0.250 wall tube, and they use 23mm FJ80 TREs. For the pitman arm, simplicity says to get a pitman arm adapter from Sky, that way you don't have to modify the one that hopefully comes on the IFS steering box.
It CAN be done, but after you spend a couple hundred on the arms, then a hundred on tube (depending where you get it of course), and more for the ends, you might as well have bought it in a kit IMO. Price it out and see what you can do! Don't forget about buying the plate to make a frame brace for the box with as well, and don't forget to figure in the cost of getting an IFS box as well.
Sky has a kit on sale WITH a box right now for only $469. Good deal IMO!
~T.J.
~T.J.
thats funny you should come make my steering then!!!! my shiat was done good and yes they use fj 80 tre, and i didnt thats why i said its a waste of time and effort dont bash someone stuff till youve been there... i answered the question at hand truthfully.. its not worth making your own!! and just to let you know i had two steering set ups made by two different people that claimed they wheeled their **** for along time with no problems. first trip out i fawked one of them up!! also where you gonna get tubes with the threaded insert for the tre? this is usaly where the problem lies ask around? i think crash has had a few experinces with making crossover steering. back in the day and i remeber when he told me to not waste my time and buy the kit!!
0 Words
