Cascade_Crawler
So where can I get some custom flexible brake lines made? Anyone know of a good place for a reasonable price?
CrustyJeep said:You sure you need custom? OEM > custom IMO, if they're readily available.
Details
Technically yes, you are incorrect, but it will take some fab work. Personally, I'd do the work and run OEM lines. You could flare some extension hard lines, and put stand offs on the frame to match your lift; better than aftermarket lines if you're setup to do the work.XJonathan said:Well with my upcoming spring over my stock rubber YJ lines won't be long enough even if I relocate the hardline on the frame. Am I incorrect?
Boxxerace said:Per this fella working at Shucks (of all places) off 128th, everett:
There is a hydro-hose service company (maybe for trailers?) just south of the trestle (spell?) on evergreen way that makes whatever length / fittings for $25.00 each.
If I ever make it up there, I will get more detailed info. Nice Price if its true.
Freeride said:I believe Greenshields charges like $37 a line or something crazy like that. Olympic did 3 for me for $86. Really nice lines, exactly the lengths and ends I needed. No hassle of looking through parts books.
