Cut 44 boggers with built tons??
1tonyj
Panama City
Wanted to see what you guys think and if anyone runs close to the same setup and how they like it or not..... I have never run boggers before...that being said my tires are worn out and I got a good deal on some like new 44 cut boggers. These things are nasty looking compared to the tires I have been running (44 TSLs...Aetan cut in rear and TN cut in front) and Im a lil concerned about my axles staying together lol.
My axles are Dynatrac Pro Rock 60 front with RCVs, Dynatrac Trail 60 rear with chromos, 5.13 gears and Detroits at both ends.
My Drive train is TBI 350, NV4500, Atlas 3.8
I live in Florida so I wheel diff kinds of terrain....but we do make several trips a year rockcrawling.
i am running 44 cut boggers on a 14 bolt and gm king pin 60 in a bouncer with an ls th350 and lomax and only thing i have broke was a 30 spline stub shaft went up to yukon 35 spline no issues yet
you should be good with that set up and i love the way my cut boggers pull
I have non-cut 44'' boggers in a fairly heavy truggy, on heavy H1 double beadlocks that have 1/4 thick rock rings. RCV's/4.10's in a high pinion 60 for the front axle. Sterling stock 10.25 in the rear. I was breaking driveshaft joints before anything else. Now I have 1410's all the way around and have not broken anything since. You should be ok.
What joints were u runnin b4 1410 switch?
Got um on today.....guess we will see how they do at GMP.
I know lateral traction sucks with boggers so I may cut them like the ones on TC's old buggy Hell Raiser.....i know you guys will call me a :tc for that lol.
