84Toyota4x4
So, this is on my fantastic daily driver, a 1995 Ford Aspire :haha:
About a week after I bought it (after sitting for three years), it started acting kinda funny if you put your foot into the throttle a too much while trying to accelerate quick (more than 3/4). It kinda acted like it was running lean and detonating or something, or it hit a rev limiter and just kinda stumbles. If you leave your foot in it, it eventually "catches up" and smooths out.
I did a full tune up on it with plugs, wires, fuel filter, PCV valve, O2 sensor, dizzy cap, rotor, and an air filter. This seemed to help as the problem wasn't noticeable really for a while after that. Jump forward 6 months or so, the problem started coming back, and I was just kinda living with it.
Jump forward a month or two more. The other day on the way home from work, I was at a cruise and it started doing it. Normally it was only if you accelerated too fast, but this time it just started doing it without even moving the pedal. In the two more blocks I had to drive to get home, it got to the point where I couldn't give it ANY throttle off an idle or it would stumble and try to die. Let off, and it would recover and idle smooth.
I parked it when I got home, and came out a few hours later to tinker with it and noticed that cold, it starts right up and runs fine. However, as soon as it gets hot the problem comes in hard and fast and you cant touch the throttle anymore.
So, my diagnosis is limited, but I'm thinking along the lines of the TPS Sensor, the MAF Sensor, or maybe the coil or pickups in the distributor or something? I kinda rule out the tune up parts because they only have a few thousand miles on them at the most right now. I'm thinking sensor of some sort.
While idling, I tried unplugging various sensors (TPS, MAF, etc) to see if they made a difference, and I couldn't get it to do anything different with any of them unplugged. Didnt get any better, and didn't get any worse. Also, no check engine lights came on, and it doesn't show any codes with a generic scanner hooked up.
So, any one have some opinions? :corn:
~T.J.
~T.J.
