dana 44 arb setup
85b2man
bothell wa
so i am setting up my dana 44 arb finaly or trying to so its the style with the air inlet on the non r/g side so do i just press both bearings on and the shims go on the outside of each bearing
dam arb is closed so what if the shims on the ring gear side needs to be thiner than the master shim do i use it ?
fricken #*%# G#$ so i got the arb all set up it was golden then i put it in the bed of my truck and aparently i took a corner to fast and it tipped the box over so i just got home and see all these little bearing in the bed of my truck #(%( the bearing exploded awsome :awesomework::fawkdancesmiley:
