ballistic maybe? They used to at least
offroadoverstock.com there the ones thats on infernaljeeps taco on pirate
Trail ready will convert your existing aluminum wheels for 175.00 each.
It's a tricky process to do and they have it down to a science. The rim flange is machined away, flipped and "wire fed" back on. The bolt flange is TIG welded on along both the inside and outside surface.
They earn the 175 bucks.
I know. I would love to have them but Im maying to have my rig finished right now. Out of budget.
Do you know if they heat treat them after weld to draw them back to T-6?
If your out of budget then why are you trying to do alum locks? Dont ya already have rims and tires mounted?
No.
The aluminum rims you buy off the shelf are not heat treated anyway, usually just cast or cold forged at best.
Thats what I did.Trail ready will convert your existing aluminum wheels for 175.00 each.
