Do you have less than 5G in your rig?
ian from xtreme
Active Member
I am building a "Dirt Cheap Wheeler" on Xtreme this year...I am looking for a couple locals who have "no money" in you rig and want to come out for a trail ride with us. Will more than likely be at Wooleys because they are the closest to the shop and easy for our crew. Ride will be around Christmas on a Saturday....post up a pic of your rig in this thread and some info about it. If it looks like it will fit the show I will send you a PM
Re: Re: Do you have less than 5G in your rig?
87.samurai 4.3 duel fuel propane,th350/dana 300 homemade twin stick shifters, home built drive shafts,toy front 30spline longs aussie locker,trail gear high steer, toy ifs ps box. rear toy axel stock welded, yj spoa, diy beadlocks cut 33 boggers, exo cage,harnesses.
I bought it bone stock and built it .
I have around 4500. in it and I have a blast.
Sent from my DROIDX using Tapatalk 2
it is a 83 Toyota cab truck
drive train
1 22r on propane
2 g52 trans
3 two stock cases with trail gear adapter with tg twin stick
front axle
1 83 Toyota housing
2 529 g2 gear set
3 Detroit locker
4 fresh rebuild kit on housing
5 new g2 chromo axles 10 year replacement
rear axle
1 ifs housing
2 529 g2 gear set
3 spool
like brand new 38 tsl tires
Front springs are toy rears
Rear is four link with tj coils.
Got the truck for about nothing. I done all
The fab work myself. An the parts I have I got a pretty
Good deal. Got right a 4200 in mine.
The Gremlin
Built Toyota
Lots of cheap tricks
Linked front air shocks
Full hydro
Duals
Safe
1990 Samurai
EFI
4 links
34's LTB's
Yota axles
100" WB
Exo-cage
5 to 1 t-case gears,
'03 Dodge Neon seats
Power steering
Welded rear
5 gallon fuel cell
To break up all the Sammis.....
98 TJ
4.0 with 250k miles
ax15
NP231 with sye
Ford 8.8/ 4.56 & Lockrite
Dana 30/ 4.56 & Lockrite
Homebuilt front radius arms
33" mud brutes
2002 tj 4.0 reads 185k but no idea true mileage as the odometer has never worked
D30 frt 4:88/ 8.8 4:88 rear
35's 3 km2's 1 km1
Goes great I've got about 4300 in it so far, it's a little rough but runs great and I still run it to work every day too.
here is mine....
96 Ford Ranger SC
4.0 V6 auto...all stock
DD Machine Doubler
frame shortened and wheelbase 10"
Front King Pin D60 with 4.88 and welded diff
Rear D60 out of a Dodge with factory disc brakes 4.88 and welded diff
leaves front and rear
fenders painted now (willy make it)
84 toyota pickup
38.5 boggers on DIY bead locks
22r on propane with a little work on it
Locked f/r
Longfields
Chevy 63" rear springs (modified) rancho shocks
Homemade pack up front with bilsteins
TG hi steer with ifs box
TG drive flanges
Custom flat bed and bumper
Dual transfer cases
Square tube driveshaft.
Sent from the mans IPhone.
Local to woolys here in Huntsville.
$400 xj
junkyard leafs pieced together,
44 locked and geared.
Stock front locked and geared.
5" coils
3link front
Homemade steering setup with high steer.
Worn out mud tires on steel wheels
Home made bumpers and sliders as well as frame stiffeners.
Lots of garage fabbed parts and money spent in all the right areas
(Old picture with krawlers)
88 Jeep Cherokee 4.0 auto with 231 locked 30 front, welded 35 rear "soon 60 and Sterling", exo, on 34 LTB's with APC seats, harnesses front and rear. Even after the tons are under it will still have less than $3500 in it of course that was with the help of some good friends and their "old used up" parts and labor helping.
Bought not built. Even with price I paid plus upgrades/replace parts its under $5k
4cyl toyota engine on propane, w56 transmission, dual toyota cases, d44/12 bolt out of a chevy spools and shafts. Worn out red labels on beadlocks
Sent from S3
88 samurai. Toyota axles 4 link rear and stretched. Low gear case and all other drive train stock. Built from everyone else's scraps and beat on for a few years now. I'm in !!!!!!! But better yet let's challenge your low budget rig to mine. Come to golden mountain and play follow the leader?????
80 cj7
351w with duel fuel, t19, dana 300, dana 44 front, 9" rear, streched with 63" chevy springs rear and homemade yj springs up front.
Sent from my DROID X2 using Tapatalk 2
Stock 4.0L on dana 44 and 9". ARB in the front and spool in the rear 4.86 gears. Dual stock T-cases 36" swampers on DIY bead locks. I have less than 5k in it for sure.
