J
Joc
Guest
I've worked my current job for 7 years and have always wondered if there is software that could save me time.
My job consists of cutting large quantities of glass. Some weeks we may cut 20 sheets of glass others we may cut 50 sheets. It can take anywhere from a hour to 4 hours to "map out" the sheets before cutting can begin. It just seems like the biggest waste of time.
We use 4' x 7' sheets and 3' x 7' sheets.
I calculate hundreds of different sizes each week and then have to draw a rectangle and start placing sizes in the sheet as tight as possible in order to use as much as possible.
Is there a program that I can enter all the sizes into and it map out the sheets? There might be something like this for metal but with glass once you start a cut you gotta go all the way to the other end/side. no stopping in the middle or you've just left the door open to a crack running out into the remain section.
