Dual case order?
R.DesJardin
10
Clarkston, WA
For the dual case install which case is in the front, the reduction box HI-Low, or the IN-OUT-Hi-Low box?
I've search around but haven't found a real answer.
Thanks,
If I am understanding what you are asking... it is pretty simple to figure out on your own...
You take a WHOLE transfercase, and put it behind PART of a transfercase... :D
:rolleyes: 2.28 gears in the front box and 4.7 gears in the transfer case in the rear...:awesomework: thats what i run!!!!Oh ya make sure you put in a bobby long output shaft in while it's apart or you might reget it latter when ya have to fix it on the trail!!!!!:awesomework::awesomework::awesomework:
