Education: Drive By Wire
  • Thread starter Thread starter InDaShop
  • Start date Start date
I
InDaShop
Guest
So what's the scare? Why are so many people shying away from this setup?
Wiki-wiki-wow:
Electronic throttle control (ETC) is an automobile technology which severs the mechanical link between the accelerator pedal and the throttle. Most automobiles already use a throttle position sensor (TPS) to provide input to traction control, antilock brakes, fuel injection, and other systems, but use a bowden cable to directly connect the pedal with the throttle. An ETC-equipped vehicle has no such cable. Instead, the electronic control unit (ECU) determines the required throttle position by calculations from data measured by other sensors such as an accelerator pedal position sensor, engine speed sensor, vehicle speed sensor etc. The electric motor within the ETC is then driven to the required position via a closed-loop control algorithm within the ECU.
The benefits of ETC are largely unnoticed by most drivers because the aim is to make the vehicle power-train characteristics seamlessly consistent irrespective of prevailing conditions, such as engine temperature, altitude, accessory loads etc. The ETC is also working 'behind the scenes' to dramatically improve the ease with which the driver can execute gear changes and deal with the dramatic torque changes associated with rapid accelerations and decelerations.
Contrary to popular belief[citation needed], except in concert with other technologies such as gasoline direct injection, ETC provides only a very limited benefit in areas such as air-fuel ratio control, exhaust emissions and fuel consumption reduction. ETC however makes it much easier to integrate features to the vehicle such as cruise control, traction control, stability control and others that require torque management, since the throttle can be moved irrespective of the position of the driver's accelerator pedal. A criticism of the very early ETC implementations was that they were "overruling" driver decisions. Nowadays, the vast majority of drivers have no idea how much intervention is happening.
Much of the engineering involved with drive-by-wire technologies including ETC deals with failure and fault management. Most ETC systems have sensor and controller redundancy, even as complex as independent microprocessors with independently written software within a control module whose calculations are compared to check for possible errors and faults.
Anti-lock braking (ABS) is a similar safety critical technology, whilst not completely 'by-wire', it has the ability to electronically intervene contrary to the driver's demand. Such technology has recently been extended to other vehicle systems to include features like brake assist and electronic steering control, but these systems are much less common, also requiring careful design to ensure appropriate back-up and fail-safe modes.
Nolen, and now Cole have went or are ditching the Drive-by-wire system for their throttles. My buggy still has it, I like it because of where I was able to mount the pedal for ergonomics, i.e. move it from where the builder put it. Now I don't really get any peddle feedback, per say, like you would with a return spring system..... And my throttle is kinda twitchy. Would I be able to solve the twitchy-ness by going with a manual throttle body?
I never noticed any problems, but Kelly drove it, and complained the whole time. So :dunno:
Yeah its the exact same part# in the D-max as the buggy (woohoo spare parts: rob the towpig). But I drive some many other things with enough routine, that I really dont notice a difference in the throttle coming on or not. If people are changing because of they dont like the pedal "feel" then thats a whole nother story.
I just want to understand the system more, the differences, and why are people going back in technology? What am I missing?
Cheaper parts if the cable dies than the entire DBW assembly and easier to find/fix/rig to make work. That'd be my guess
wngrog said:
Simplicity......a shoelace will fix mine if it breaks.
TRUFAX
My motor mount broke in Moab 2 years ago and left my throttle PINNED in the lovely WOT stat. I took my throttle cable off, used my shoelace.. Worked great in a bind(except for it stretches when you pull, so damn jerky ) laughing1...halfway back to the trailer, I encountered another issue with my motor----caught on fire laughing1 Damn bunny trails will get ya every time.. I wasn't doing **** by my **** was falling apart! laughing1 Techtafab ended up towing me back to the trailer. Lovely day... I am now an extreme advocate against carbeurators!!! Damn I hate those things. Fuel had sloshed around so damn much got my crappy vatozone edelbrock foam filter soaked with gasoline then caught fire somewhere in the process...
carbeuraters are for tru ballers
If that were to happen to my, guess what? No cable to bind. :flipoff1:
Ok I had drive by Wire on Fireball and it was ok.However it seemed to hesitate a little when you matted it from a dead stand still and it had a few other quirks.
With Cable, there is no hesitation and it's just simple.
With that said I am converting my motor to Mechanical TB.
