Electrical problem
JPTHING
Oceanside, Ca
Hey I have been having a problem, got my Xj running, and I now have a problem with my electrical. The guages, the heater, radio, stopped working all the sudden, is there a common area that I should look into, to see if that might be my problem. Thanks for the help.
Dash fuse? Common ground? Did you work on anything just before they stopped working? If so go back over everythign you did, mabye something got missed on reassembly.
yes check grounds, also were you in the dash or wires at all, start there.
1-fuse?
2-does the fuse have power at both prongs?
3- if yes and yes.. start following the poiwer wire for cluster
