FJ40 Cage and project completion
I redid a few things on the cage, mounted the winch, and started making some spring mounts. Thanks Cascade Crawler! I'll be moving the seats forward a bit. They are a little to "gangster".
I've got a roller fairead you can have for that 8274......it's just layin the junk pile in the corner.
I love that dovetail job with the single halfdoor. Very slick. I'm saving some of these pictures for later use :cool:
I forgot to leave you a new blade for the portaband, hopefully its still cutting.
It broke on the first bracket I tried to cut. No worries though. I purchased 3 more for good measure.
And, yes it is a factory cruiser frame. It is a total pain to try and make brackets for. Nothing is straight or on the same plane. The frame changes width all over the place as well. :puke:
More stuff. Bobbed the corners of the frame. Made some shackle hangers. I also got it to run a bit better while I am waiting for tabs.
Did you run the overhear spreader bars straight down to the point in the brow? Does that interfere with overhead room?
Yes I did. No it doesn't interfere with head room. There is 5+ inchs of head room right now. It's pretty similar to my old YJ. It looks a little weird without aluminum on it.
