It's probably the synchronizers. The factory clutch forks all bent in them which caused the clutch to not fully disengage & it is hard on the synchronizers. It's usually 3rd gear that gives trouble. Ford makes an updated fork that doesn't bend. The factory pressure plate is also bad about getting hot &causing the springs to get so stiff that the slave cylinder can't create enough pressure to disengage the clutch.
