Found This "14 Bolt 40 Spline Mini Spool"
BradWester
Anniston, Alabama or Fahaheel, Kuwait
I found this article and figure someone on here might could you the info. Sounds like a fair deal if it would hold up?????!!!!!!?????
14 bolt, 40 spline, spoolApr 19, 2013 at 9:07am
Quote
Post by David Bryan on Apr 19, 2013 at 9:07am
Hello. Now in stock. 14 bolt, 40 spline, mini-spools. These are a two piece mini spool, that simply bolts in to a four-pin cross carrier. The 14 bolt must be an "open" style carrier. These are the four-pin. The limited slip style carrier is a three-pin style, and will not work. Machine work is required on the stock, open carrier. The hole for the 40 spline axle shafts must be increased. The hole for the side gear (now mini spool) must be increased as well. Simple to do at a machine shop. We also offer an exchange program. You send us your good, clean, carrier, we then machine it and send it back to you with the mini spool.
After a few trials, we are confident of the quality. These are proven behind both automatic, and manual transmissions. Not one failure.
Introductory price is $180.00 plus shipping. Machine work on your carrier is $100.00.
Thank you for reading. David Bryan
David Bryan
Raptor Fabrication
Builders of Dana 60 and GM 14 bolt assemblies. Only the very best.
[email protected]
Please, NO pms.
E-mail is best.
Read more: http://wesmash.proboards.com/user/1006/recent#page=2#ixzz2XV9wvJZf
