Birdbrain
Anyone here run it? How do you like it? Pics of how you mounted it?
Lots of issues with cracked cases and loose bolts with that mount. Yea it works but having all that drivetrain only supported on the ends tends to be a bad thing after awhile. Everyone I know that runs it has had the same issues. Maybe you'll have better luck.
.......also if you use their poly bushings make sure you put some poly motor mouts in to match it up. other wise you will put unneeded stress on the case.
