fuel cell plumbing
cisco
Sea Town
Thanks for the tech, why would you use a sealed cap with a vent roll over valve? I know every one does, just wondering what the benifit is. Seems like the one way valve in the cap would do the same thing but maybe not.
Why would you want a vent to be one way? It needs to let air in as fuel is used and also allow air out if the rig is say parked in the sun for some time and the fuel heats and expands. Also don't trust the roll over valves, they usually don't work for ****.
I see your point about letting the pressure out when the gas expands. I wonder why the fuel cell was designed with a one way valve?
I just think it would be extra strain on the flow. It would have to push fuel out of the way to flow in, where as the top is just pours in.
~T.J.
I ran mine original this way years ago w/o a problem. Others have done it with different setups (motor, pump, etc...) and had nothing but issues.
X2......My 4.0 in the Xj had the return right next to the outlet with NO probs then the same exact setup in the 5.0 and the thing wouldn't run.It was sucking the airated fuel right from the return and wouldn't take a load,switched the return to the top of the cell and NO probs
If you were getting airated fuel from the return something else was wrong....
