Fuel Injector connector clips
whiterice
Lynnwood
'87 Toy 22RE, the engine is loaded with these little elec. connectors that have a square plug-in. There is a retainer snapring type clip that holds the plugs together. Ex. the electrial plugs for the fuel injectors. Now my question is , how do you get them off without breaking them or spending a few min. each plug with a knife or screwdriver and pry the spring down then pull the plug. Is there a cool little tool for removeing the clips? If so, where can you buy one?
84Toyota4x4 said:
Arent they the standard plugs that you just push down on the metal wire and pull the plug off?
~T.J.
The japs were not that smart--you have to peel the U-shaped metal clip off...
Or mabye they were.... They may be a PITA but at least I've never seen one of those fall off on it's own. :haha:
Yeah, I always just use a small pick for those... kind of a pain, but you'll get the process down real quick and it won't take you too long per clip.
I have. As soon as the plastic breaks and the clip becomes useless, they slip right off. I can't remember ever seeing a car without at least one of those things busted :rolleyes:
Yeah... that usually happens when some jackass tries to yank it off without unclipping it first. :mad:
