Fuel problems....
Paulie
Looking for man love
Whores nest
First off lately my guage inside hasnt been reading right, when i have a full tank of gas it reads little over half a tank of gas but will act like a normal guage and drop fuel level to empty, seeing how its a half a tank and guage reads emtpy. anyone have this problem, im almost thinking its a sending unit inside the tank but i want to know other options before i drop the tank. also today i had a weird problem filling up gas. i went to chevron in snohomish, gas there is $2.35 a gallon, toyotas have a 12 gallon tank if i remember right, supposidly i filled 18.5 gallons of fuel in my truck using up to $43.75 exact. What the **** is with that, cant i call there main office and file this complaint. i got a receit for everything and it shows proof that i spent that much money in gas when its $2.35 a gallon on a 12 gallon rig. anyone care to help with this one too.:rolleyes:
Paulie
I had this exact same problem with my '85 xtra cab. Full tank would only read a little over half.
My guess is that somebody swapped in the wrong sending unit at some point, which could be the case since Mark says they do have an 18 gallon tank... maybe somebody swapped in a sending unit from a 12 gallon tank, which is somewhere in the ballpark as far as how far the gauge is off.
i figured by filling it up with $35, gas being $2.65ish fills it completely and pump use to show 11-12 gallons around that, owners manual states a standard toyota is 12.3 gallons.
guage worked perfect, never had this 18 gallon problem before. i filled the truck completely a few times and it was normal cause i knew how many gallons and average price it would be. its just in the guage on the cluster or something is ****in up in the tank. what would cost it to do this, ive never seen it on others.
Mine has about a 17 or 18 gallon tank.
As for the gauge problem, the armature inside the sending unit gets bent away from the windings over time with the fual sloshing the float around and crap, so it makes contact intermitantly and sometimes in the wrong places. Drop the tank, bend the arm back, and use the FSM test procedure to make sure the gauge checks out ok (light bulb trick), along with measuring the resistance of the sender to make sure it reads 100% through the armatures movement cycle. Been through this a couple times now.
~T.J.
while its out get the ohm range from the book, and test it, THENNNNN test it wet also, that can change it and screw you for a re-drop! also, look in the tank and make sure that bouncing hasnt broken the slosh baffle loose, those suck!!
I had to get in there & fool with the sending unit on mine a couple years ago. It would hop from 1/2 to 1/4 & drove me crazy. My 90 runner came with a 17 gallon tank.
they is they get crappy contact/conductivity somewhere in the range it will jump. i always just suggest replace, theyre cheap.
The tanks are ~16 and ~18 gallons. You were on fumes and put a half gallon in the neck. :flipoff: Been there done that.
Show me where you can find a sender please! Ive been looking around off and on for a long time now...
~T.J.
