Gear pattern what???? Bent housing??
Looks like there is something wrong but probably not a bent housing. If the housing were bent the pattern should be consistant. My guess is ring gear not seated, bent pinion, bad carrier and or bearings, carrier mooving side to side while checking the pattern....something along those lines. Someone needs to check for runout of all these things with a dial indicator, shouldn't be hard to find.
id check for run out, posably flip it 180 degrees, see if that fixes it..
and who'd waist $ on putting an aburn in a 8.25????
to hell with it.. run it.. you know its just going to break any ways.. might as well be a 35....
0 Words
