Alright, here's my problem: I daily drive my Dodge CTD, but I don't drive a long ways to get to work. I figure this is a typical problem for some of us. I plug it in every night, but it still takes forever to warm up in the morning.
Starting it ahead of time and letting it run for 10-15 minutes does no good, it never even registers on the temp gauge after idling for 15 minutes. The only way to get it heated up is to drive it.
Anybody have any suggestions for getting it warmed up a "little" more in the morning, so I at least have some heat and a little less wear and tear on the rig on my way to work? I drive about 10 miles to work and on cold mornings, the temp gauge is usually not even in the "operating" range by the time I get there.
Grill covers? Different t-stat? Is this normal for the CTD, or do I have a bad t-stat? Once it does heat up it stays there a little above or below 190 depending on what I'm doing with it.
Also, along these same lines... am I assuming correctly that the heater I'm plugging in at night is not a block heater per-say, but simply the intake manifold heaters? Would adding a 2nd block heater do me any good?
